A20m "heating done"
steve rebeyrol
A20m "heating done"
Post by steve rebeyrol »
Hello
I buy 2 A20M and sometimes the print stops with the message "heating done". do you know where it comes from? thank you
Re: A20m "heating done"
Hi, How to display the temperature above LCD?
you can measure the resistance of the thermistor on the motherboard and the resistance of the hotbed.
steve rebeyrol
The temperatures on the LCD are like when the printer is switched on: the order of the nozzle and the heating plate are at 0 but I can see the temperature. There is just the message below "heating done" instead of "A20M ready".
Okay but start measuring and I have to look for what?
thank you
Hi, you can measure whether the power supply output voltage reaches the rated voltage; then check if the wiring is intact and the wiring may be poorly connected or damaged. The resistance of the heating cartridge is about 3.6ohms
steve rebeyrol
ok thanks I look this and I open a new post because other problems arrived.
thanks
