Ok so I was looking to upgrade the 2 x bowden extruders on my A10M to 2 x Metal Titan extruders.  The only Titan Metal ones I can find all state they're for the MK8.  As the A10M is V7 MK10, I'm assuming these wouldn't fit?
In the very near future (like 3-4 weeks) I plan to also get a 3-1 J-Head Triple Multi-Color 3 in 1 which IS a V7 MK 10.
SOOOO
A) Are there 2 x good metal titans for the current A10M 2-1 people can recommend
B) Would they be good to use in the future with the above mentioned head or would they need modding/different exturders
C) Noob question but when I have the 3-1 J hotend I can purchase a 3rd extruder + filament detector which would then be ok to add  (obviously with some calibration)
						Titan Extruder Shopping help
Re: Titan Extruder Shopping help
Hi, the nozzle type of A10M is m7 thread; It is not the standard MK10 4mm inner diameter nozzle. you need to check it at first. the default inner diameter should be 2mm.
Thanks I shall remember and look accordingly
