Setup Problem
Setup Problem
Hello, I just bought an A10, and the set up all went smoothly, but when I plug it in, the display does not turn on, but when I was moving the tray, I noticed the screen lit up a little. I don’t know what’s wrong or what I’m doing wrong.
						Re: Setup Problem
Most likely your ribbon lcd connector is loose either way by lcd side or motherboard side. Check them, reconnect and lock.
						Re: Setup Problem
Hi, You can try to re-plug the cable to the LCD screen.
