A10 problems
Nipper2803
A10 problems
Hi all. I started a print last night on my A10. woke up this morning and the print had finished but fell apart after taking it off the bed. i cleaned the bed and set up for another attempt. When i selected auto home the printer started making banging noises when close to the bed. there is a gap between the nozzle and the bed so not sure what to do. i do have a 3dtouch as well connected.
Re: A10 problems
Hi, have you checked if there is any line pressed? Perhaps this is not the case with insufficient printouts. You can try to modify the amount of extrusion. ABS material usually has a 10% extrusion, while PLA is 105%.
Re: A10 problems
Hi, today has arrived my geetech a10 (I have bought that one from Amazon) but the metal profiles are ruined, it seems used. Has it ever happened to others?
