Feed motors don't turn when printing
Chub
Post by Chub »
What did I do to stop the filament feed to not turn? I calibrated the E step now no feed during print. If I load/unload filament they turn fine. I have an A10M. Even the dog doesn't print now.
Yes, I get filament out during loading of filament. Doesn't appear to be clogged.
Re: Feed motors don't turn when printing
Hi, You can try to clean the nozzle first. you can refer to this:http://www.geeetech.com/forum/viewtopic ... 15&t=68695
Chub
Post by Chub »
Nozzle has been cleaned, HotEnd has been cleaned. Removed the filament and reloaded. Gears turn for this but not during printing. I even tried to print something I previously had no problem with. This issue is for both of my extruders. I changed the mix from 100/0 to 0/100 and still nothing. Is there something that I inadvertently changed on my display? The dog gcode should not have changed so that should have printed. Gears don't turn up by the filament.
Manu.B
Post by Manu.B »
Just check if your flow is not at 0%.
You may also reset the settings to default
Last thing, Update the firmware with arduino 1.8.5
Chub
Post by Chub »
This brings up another question not related to extruder flow but since firmware was brought up, is it worth having a BLTouch? To do this I have to update firmware anyway. So if updating the firmware for the flow, then I might as well add the BLTouch and stop trying to level the bed myself. Does this make sense? Anyone else happy they have the Touch?
Thank you for the advice and suggestions
