I've recently got the auto leveling sensor from the Geeetech store for my A10.
I've installed it and flashed the firmware as per the topics on the forums, and all the leveling seems to work.
The issue I've got is when I go to print now the print head homes and levels but then starts printing without moving the head, the head stays at the home position and the extruder seems to extrude really quickly and I end up with a large mess of melted filament.
Any help appreciated!
EDIT: Further investigation shows that the head homes fine and shows X and Y at 0 but this doesn't change when printing. If I send a manual GCODE to try move the head it doesn't move, yet when I manually move from the LCD panel it works...
						3D Touch Issues
Re: 3D Touch Issues
Hi,you  can  refer to this: http://www.geeetech.com/wiki/index.php/ ... ing_Sensor
I hope this can help you.
Re: 3D Touch Issues
Thanks for the reply but the instructions look to be for a different board than mine? I have the GT2560V3 and the layout is completely different?
						Re: 3D Touch Issues
I've managed to fix this by using the 1.1.9 A10 firmware provided on the forums, so not sure if I flashed the incorrect firmware originally but I used the A10 with BLTouch as recommended...
