MINTEMP
Re: MINTEMP
Hi, You can check if the thermistor wiring of your hot end and hotbed is fully connected.
If it is fully connected, it can be measured.
and you can refer to this: http://www.geeetech.com/forum/viewtopic ... 23&t=17030
I hope this can help you.
Re: MINTEMP
Hi, thanks for your answer. I tried to figure out what to do, but I'm not sure what I'm looking at
Could you be more specific which connectors I should be looking at (I attached the image of the board)?
Thanks!
Thanks!
- GT2560_v3.0.jpg (226.94 KiB) Viewed 2513 times
Re: MINTEMP
Hi, You may need to check to see if the extruder's thermistor is fully connected.
