Bed thickness?
Bed thickness?
Is it just me or is the a10m bed really thin. My last printer had a good thick bed. Wouldn't a thicker bed be more flat?
Re: Bed thickness?
How is the print effect?
Re: Bed thickness?
The glass on top is 1/4 inch thick but the aluminum heater plate below that is really this and is not really flat. Shouldn't that aluminum heat plate he thicker to remain flat better?
Re: Bed thickness?
Hi,Are you referring to the gap between the glass plate and the aluminum substrate?
I am not very clear what you are referring to,
However, if the print plane is not flat, it will affect the printing effect.
Re: Bed thickness?
just refferig to the aluminum plate now the glass.
my other printers have thicker NOT bendable aluminum heater plates. just wondering if this thin plate with the A10M is normal? or should i have a thicker one? glass or not it would be easier to level if the aluminum under the print surface was not bendable. just thinking.
Re: Bed thickness?
The Mylar + Aluminum substrate is indeed a little thinner.
