Hi!
I've never noticed this issue before as I've been printing from an Octopi, but now I wanted to print from SD Card and the printer randomly pauses. This does not happen when printing over USB.
Does the A30 have issues with SDCards of a certain tech type or size? The same SD cards work fine on an A10 and several CR-10. Is there a list of known-to-work SD-Cards that will definitly work with an A30?
Thanks!
A30 SDCard issue - print pauses randomly
Re: A30 SDCard issue - print pauses randomly
Hi, perhaps the poor contact of the transfer caused this to happen.
Sorry, I have no clue what you're trying to tell me...
I used to get the same problem when I used an extension cable so that could plug it in at the front of the box. I went back to the standard card it worked fine. I have since got a different extension cable and that works fine. So i would think either the card is dirty or not seating correctly. Try a different card?
