Code: Select all
Arduino:1.8.11 Hourly Build 2019/09/30 10:33 (Windows 10), Tarjeta:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
from sketch\BlinkM.cpp:5:
#define X_MAX_PIN -1
#define X_MAX_PIN 24
#define Y_MAX_PIN -1
#define Y_MAX_PIN 28
sketch\pins.h:2958:0: warning: "Z_MAX_PIN" redefined
#define Z_MAX_PIN -1
sketch\pins.h:1375:0: note: this is the location of the previous definition
#define Z_MAX_PIN 32
from sketch\SdBaseFile.cpp:21:
from sketch\Sd2Card.cpp:20:
from sketch\ConfigurationStore.cpp:1:
from sketch\MarlinSerial.cpp:23:
from sketch\thermistortables.h:4,
from sketch\Configuration.h:792,
from C:\Users\Mariano\Desktop\ð-¢¿+-+¦+ð\I3proW\Marlin\Marlin.ino:33:
sketch\Marlin_main.cpp:2667:36: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
In file included from sketch\SdBaseFile.cpp:24:0:
SdBaseFile.h:38:8: error: using typedef-name 'fpos_t' after 'struct'
struct fpos_t {
c:\arduino-nightly\hardware\tools\avr\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
sketch\SdBaseFile.cpp: In member function 'void SdBaseFile::getpos(fpos_t*)':
SdBaseFile.cpp:298:8: error: request for member 'position' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
pos->position = curPosition_;
SdBaseFile.cpp:299:8: error: request for member 'cluster' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
pos->cluster = curCluster_;
sketch\SdBaseFile.cpp: In member function 'void SdBaseFile::setpos(fpos_t*)':
SdBaseFile.cpp:1496:23: error: request for member 'position' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
curPosition_ = pos->position;
SdBaseFile.cpp:1497:22: error: request for member 'cluster' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
curCluster_ = pos->cluster;
from sketch\cardreader.h:8,
struct fpos_t {
from sketch\SdFatUtil.cpp:20:
Se encontraron varias bibliotecas para "LiquidCrystal.h"
Usado: C:\arduino-nightly\libraries\LiquidCrystal
exit status 1
using typedef-name 'fpos_t' after 'struct'"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
