Cura for duplicator 5
moonraker
Post by moonraker »
Hi guys, Ive tried out cura with flashforge creator pro profile to slice the gcode and its a lot better then slic3r, making the printer actually usable, but there is no way to print directly from cura, only by importing gcode to repetier, is there a chance you might know the workaround to print directly from cura ?
Re: Cura for duplicator 5
Hi, Cura also prints files in STL format to generate gcode for printing.
moonraker
Post by moonraker »
the slicing is fine is just exporting it to repetier is a bit of a pain, cannot just press print in cura
