normally the Bltouch is to the left of the hotend, but i switched to an E3D V6 and now my Bltouch is to the right and a bit in front of the hotend. Where can I set the parameters to change the position, so that the mesh bed leveling finds the correct spots again?
Thanks a lot!
Best regards
Bltouch position settings
Re: Bltouch position settings
ok I've dont that and changed it via the M851 command. It seems good now, but the bed leveling now is in the wrong places. Is it possible that the x,y offset are hardcoded in the routine?vert wrote: Wed Nov 13, 2019 9:57 am you need to measure and adjust the probe offset in marlin recompile and flash to change this.
