I have a problem whit layer fan in my a20.
It dont work USB vía by cura, but yes if i configure directly in the printer.
Any idea why?
Layer fan
Re: Layer fan
Hi,If you mean the fan on the hot end of the printer,
This fan is turned on after printing several layers.
You can control the wind speed on the screen.
Gabi Nieto
Re: Layer fan
Thank William.
yes, you say the normal operation mode but in my case the layer fan never work if i setting it since cura.
why?
why?
Re: Layer fan
Hi, If you can use the LCD to regulate the fan speed on the cover,
Prove that the fan is normal, you can try to reconnect cura to try
Gabi Nieto
Re: Layer fan
Ok, i will try.
The fan work perfect since lcd printer.
