I've check all steppers, and the end of curse switch. So my machine works, I set the stop of the z-axis. I place the extruder at the point to do home setting. Done.
I tried to print a file with easyprint 3d. Well the the bed and the extruder being hot. the extruder move to the x axis end. A loud noise with the x belt during one or 2 seconds. the steppers stops.
the extruder goes to x and y home point and after, the x axis move up , the extruder is about 15mm up the bed, and the print start in the air.
what can i do , which paramater to set up to enable these 15mm in the z axis
thank you for yours advices
home disfunction
Re: home disfunction
Hi, You can check if your printer can run Auto Home normally
Then check the tightness of the belt and adjust it;
Then check if your motor can run normally,
If it is not possible, exchange other motor wires that can work normally, and determine if it is caused by a broken motor wire
Printing in the air may be caused by a problem with your gcode, you can try re-slicing and printing.
If the problem still exists, you can provide specific videos so that we can better solve.
bauchetfranck62@gmail.com
thank for your response
it's done for the stepper homing,
but for the gcode, the printer start always 15 mm in the air.
I use the version 1.0.19 for easy print becaus the 1.2.6 version doesn't work when I demand to slice and the program stop
for the 1.0.19 version, I've tried to reslice the stf file. but the printer always starts 15 mm under the bed.
What can i do to resolve this problem
Hi, Whether you print the same model;
If yes, it is the version of the slicing software
