hello all,
Do you use the Geetech's provided link to download the Marlin firmware?
I did, and checked a bit and saw that the # extruder was enabled for 1, and the singlenozzle is not active/defined.
did you had to enable and work on the firmware a lot?
if there is a stable version of the firmware that needs only certain settings that needs the end user to find out (eg. PID), I am greatly tahnksful for your guidance as to where this is located.
thanks you in advance.whatsapp web 192.168.0.1 routerlogin
Marlin firmware Config.h Extruders!!
Anurakclark
