Broken Extruder
Newls
Broken Extruder
Post by Newls »
Hi all
I've been having issues with my printer recently and it turns out my E0 extruder has broken.
The arm has snapped around the pivot point.
I bought a new extruder went to alter the Esteps and found out that it's not support with the mixer.
I''m a little bit confused what to do at the moment.
I don't actually mix the filament as it's quite poor at mixing. I use it more to switch between filaments either mid print or most often to use a different filament without changing it.
I saw someone had printed their own arm but couldn't find the print file for it.
Does anyone have any ideas of what to try next?
Thank you
Newls
Re: Broken Extruder
:D Hi, Can your extruder discharge normally?
You can check if your Teflon tube is fully inserted,
The pressure of the feeder.
Newls
Re: Broken Extruder
Post by Newls »
Thanks William
My issue relates this this post.
https://www.geeetech.com/forum/viewtopi ... 17#p105617
The actual arm on he extruder has broken.
For now i'm inserting an M92 E95 when i use T0 and M92 E430 when using T1 This seams to do the trick.
Re: Broken Extruder
:D Hi, If your feeder breaks, you need to replace it,
Otherwise it will affect printing
