3D touch A10T
Wolf88
3D touch A10T
Post by Wolf88 »
Hello sorry my lenguage,im a italian guys.
I bought an a10t, but I don't know how to connect the 3d touch sensor wires.
I can't find a guide for the A10T on how to connect the sensor.
the printer without the sensor becomes crazy and does not calibrate, does not stop and pushes the extruder on the plate with the risk of breaking everything.
Help me please
Re: 3D touch A10T
:D Hi, For the installation of 3d touch you can refer to:
3d touch接线参考.png (140.09 KiB) Viewed 5593 times
After installation, you need to update the firmware to a firmware with 3d touch,
However, there are some problems with the firmware of 3d touch, which are being repaired.
Fisher
Re: 3D touch A10T
Post by Fisher »
I'm also interested in this. I bought my A10T along with a sensor to use so I didn't have to use the "paper" trick of leveling and have tried several ways to update the firmware with no luck. The official Geeetech firmware didn't even have an option for this as far as I could tell and after following Vert's directions and trying his firmware I had the same issue of the Z axis not stopping and causing non-stop movement into the print bed. I haven't even printed anything yet due to this. Any help would be great.
BucksDanny
Re: 3D touch A10T
Post by BucksDanny »
I have also a A10 and a 3D touch, how is the software debugging going?
Fisher
Re: 3D touch A10T
Post by Fisher »
Great Vert! Will you be posting it to the download section for the A10T when ready? I've very anxious to get things rolling.
