I noticed that my temperature (hot end) is fluctuating very heavily.
When printing at 200c it fluctuates between 185 and 205 in seconds.
I tried PID tuning but it didn't help anything
You can see it in this video (it isn't sped up).
https://photos.app.goo.gl/4PtrfP3PN8k3WJNL7
I even had a print failed because the printer said it failed heating
Temperature fluctuations
Re: Temperature fluctuations
1. Check whether the hot-end wiring is loose, including the wiring on the motherboard;
2. Reflash the firmware;
3. There may be a problem with the chip on the motherboard.
I hope this can help you.
Reflashing worked thanks
