I've just recieved my new A20M yesterday. Packaging looks good, as well as the first look on the product. Very happy with this purchase.
Let's start to build up.
Everything is OK up to the time to feed filament into Extrudeur 0. The pivot is broken! It took us about 10 minutes to feed the filament. But here we are, try it!
Turn power on, check all axes movement, X and Y homing. Check and fix first layer's height.
The building plate is not flat, the nozzle is touching (not a few) on the middle of the bed when there is about 0.2mm on each corner. We give it a little more space (but what will happen on a big part sides? Warping?). Finally start printing from the given SDCard.
First layer looks good, the white filament first, keep growing, 10mm ok, a few blue....20mm, more blue. And then no blue at all!!! Only white but with only 50% flow rate.
The blue extrudeur (1, not the broken one) is still turning as the 0 but no material extrution!!!! Ok, it's starting well
So we managed to clean the hot-end, not easy to pull-out the filament, and impossible to re-feed. We had to push (very strongly, and with heated hot-end). On one side we can easily extrude by pushing the filament by hand. On the other, it's not the same story....
So we push again to extrude all the filament blocked inside the head, and try to extrude again, and again, and again.....
2 hours later, it's seems that we can extrude by hand from each side. It's midnight, we wanna know! Start a new test print. (With 2 new filament spools, both from Geeetech).
3 and an half hours to see the same thing
So what's going on?
We have to send an e-mail to the local market about the extrudeur. But for the clogged head? Is it possible to print something with this or shall we just forget that idea (I'm used to build my own printer for about 10 years, and never get that kind of issue, i'm VERY (VERY) disapointed!!!!)
