My Y axis on a brand new Geeetech board is dead, its 100% definitely not the cabling, driver or motor as they work fine on another axis, and I swapped the old board in (other problems) and Y axis works fine on that
So while i'm waiting for Geeetech to get back to me, maybe I can just move the stepper motor and cable over to the unused 6th stepper motor slot. But how do I go about doing that in marlin?
remap Y axis to the 6th stepper slot?
Re: remap Y axis to the 6th stepper slot?
Hi,You are referring to the problem with the y-axis slot on the motherboard, whether your y-axis motor end is plugged into the driver board?
millenium7
I can assure you the problem is with the board, not with anything else
As i've already stated in another post i've already tried swapping cables, stepper drivers and motors. I even went back to the old board. its 100% a problem with this board on the Y axis on that slot. So I just want to use another slot
Hi,you can tell your sales or change the y-axis setting in Arduino.
