I have a GeeeTech A10M that's been slightly modified.
What I did was replace the springs and adjustments for the bed with fixed height spacers, which alleviates the need to continually adjust the bed height/clearance. I also reaslize that even with a fixed bed location, the bed still needs be 'calibrated', and I use a BL-Touch for that.
Most of the time it works just fine, actually exceptionally well, but periodically, I have issues getting the first layer to adhere to the glass build surface, and the reason is obvious......the distance from the nozzle to the bed surface is obviously too large. I periodically verify the bed attachment points, making sure nothing has loosed up. That doesn't happen because I use thread locker on the spacer attachment hardware, but I check anyway.
This leads me to adjust the nozzle clearance using the control panel, by changing the z-offset value, to bring the nozzle to the correct distance from the bed. I only do that at the center of the bed, and leave the rest to the bed sensor software. But that operation is not what I expect.
I always do a home search to initailize the distances, then use z-axis movement to bring the nozzle toward the bed, using a single piece of paper for clearance. I then save that value into EEPROM, but the actual nozzle distance is obviously still too far away from mthe bed. It appears that the z-offset adjustments affect the nozzle height when moved manually, but not when the printer is printing.
I use OctoPi and PruSlicer 2.1, and AFAICT I'm not using any bed related commands/values. I wouldn't know where to find them, so I'm sure I don't use them. So, the printer works fine a lot of the time, but it fails periodically because of the incorrect nozzle to bed distance.
I'm at a loss, and am considering updating to Marlin 2.0.1, but I'm not really sure what options I need to setup to get the BL-Touch to work. The frustration when it suddenly won't print is driving me nuts.
Any ideas?????
Maybe Marlin SW issues with GEEETech A10M
crusader27529
Return to “Geeetech A10 Series”
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
