Hi everybody
Could you please help me out on connections for the 3D touch leveling sensor? the one that has 3+2 conectors?
Where do i connect theese? i couldn't find anywhere a good tutorial about the correct wiring to avoid shortcuts
Wiring
3-pin: Brown (-, GND), Red (+5V), Orange (control signal)
2-pin: Black (-, GND), White (Z min)
thanks for the help, cheers
A20T Leveling sensor connections
Geeetech A20T 3 mix 1
andrevanderweide
Re: A20T Leveling sensor connections
Creality Ender 3v2
Creality S10 Pro Marlin 2.0
yep, i've been whatching this, but it's a lil bit confused, i've tried both config, but it simply doesn't work. i need a step by step setting up list on what to do to make it work
