Geeetech a10 with cura
hawk0712
Post by hawk0712 »
Hello my english is not very good. but I'll try anyway. Can someone help me to properly set the A10 in cura. I can not print with a filling of 20%. The parts are pores and break when they are removed from the printing plate. just print another part but I can already see that it won't work with 70%
Re: Geeetech a10 with cura
Hi,You can see if your flow rate is set to 100%, and then change the fill, you can see if your hot end can discharge normally.
