I have install the new firmware A20T_G05_V1.1.8-2.1-3DTOUCH.hex on my A20T. I have follow the steps provide by Geeetech by video.
Unfortunately I'm facing a lot of issue to setup the 3DTouch.
1) During the callibration of the auto-home, the Z-axis will beat against the bed and tries to force 2-3 times.
2) After that If I do a Bed Levelling then The Z Axis beat the Bed.
3) If I re-do an Auto-Home then the Z Axis go only up.
What is wrong. I have to much issue with this printer. I solve it one by one, but every times a new one occurs.
Also the download of the firmware is very hard to process.
VIDEO on this link : https://photos.app.goo.gl/2CRoMvGz1nPHry2U8
PLEASE HELP ME.
Best bregards,
Issue with 3d Touch
Re: Issue with 3d Touch
Hi,you can enter the following suggestions in Repetier Host and send them to test one by one:
M280 P0 S10; push the pin down
M280 P0 S90; pull pin
M280 P0 S120; self-test – continue until you pin up / down or release alarm
M280 P0 S160; release alarm
Modify the z offset of 3d touch,
Whether to remove the limit switch of the z-axis
You can refer to: viewtopic.php?f=27&t=18371
THANKS. SOLVED
