Good afternoon, inserting a model with the .stl extension
, I click the slicer button processing begins and the program closes in seconds, despite the fact that in version 1.0.17 everything was fine and in the new 1.2.6 it turns out like this. How to fix this problem?
EasyPrint
Re: EasyPrint
Hi,my friend.
Can you provide the model and picture?
Re: EasyPrint
Tried with different models as created by mnob, and downloaded from the Internet, as well as standard 2 pieces that give also does not convert. despite the fact that I translated and printed my model until I upgraded to the new version.
Re: EasyPrint
I don't know how screenshots will help you find the problem, but here)) Maybe the problem is a lack of Windows components to work with the program?? https://yadi.sk/i/v4p-sZBcLMgzVQ https://yadi.sk/i/5ahZxSdUHzqKHg https://yadi.sk/i/Ua9zoiPoniK5vA
Re: EasyPrint
Maybe you need to download the corresponding configuration file.
Re: EasyPrint
Those that go by the standard with the program do not work as expected??William wrote: Wed Apr 22, 2020 9:24 am Maybe you need to download the corresponding configuration file.
Re: EasyPrint
Hi,it is recommended that you use other slicing software such as Repetier-Host or cura.
Re: EasyPrint
It seems like through Slic3r it turned out to achieve normal slicing. Small models printed perfectly, I check on the large one.William wrote: Thu Apr 23, 2020 9:32 am Hi,it is recommended that you use other slicing software such as Repetier-Host or cura.
