A20T bed temperature is always in display around 125-165°C
ingfraleo
Post by ingfraleo »
Hi there
I've the bed temperature indicated in the display at machine startup always more than 100°C even if the bed is practically cold.
What's wrong ? I also tried to use Gcommand to zeroise but it still keep sthis absurd value and do not let me print
anything
THanks for helping
Re: A20T bed temperature is always in display around 125-165°C
Hi,you can unplug the thermistor, if it shows -14 ℃, then there is no problem with the motherboard, it may be the thermistor problem.
you can refer to this:
Temperature error solution.rar
(471.73 KiB) Downloaded 381 times
