Cura printing in only a straight line.
Pete907
Post by Pete907 »
Hello Im using the latest version of Cura and Marlin 1.1.8 with my a10, it printed the dog fine since I installed Cura I can use the Monitor function but it only prints in a straight line about 1 in. Off of the heating bed can anyone please let me know what is wrong?
Re: Cura printing in only a straight line.
Hi,can you provide pictures or videos?
mr_fosi
Post by mr_fosi »
Did you check all your stepper and stop plugs?
My x-axis plug has worked loose a couple times when I've moved the Z-axis all the way to the top of gantry.
jatmoreno89
Post by jatmoreno89 »
I have the same problem. when the printer must make the build plate adhesion it makes a straight line
linea recta.jpg (7.86 KiB) Viewed 5479 times
Sorry, the picture is not clear, can you provide a video? I will judge it better for you.
mr_fosi wrote: Thu May 21, 2020 8:39 am Did you check all your stepper and stop plugs?
Hi, the line is long enough, you can adjust its position.
