Z axis grinding a10t
angelei
Post by angelei »
So I just got my a10t geeetech printer in and it worked great but I wanted to add auto level. So I followed the instruction video on the geeetech site and used the smatto firmware updater as it showed. It worked until I pressed the auto home button on the printer as shown in the video and the z axis began making a grinding noise and would barely move. So I figured it might be an issue with the update so I tried flashing it back to the original firmware provided by geeetech for the a10t. It still made the noise but would not move and then the LCD screen started flashing with weird characters and the smatto program crashed. Not sure what to do but I'm afraid to do anything else right now.
Re: Z axis grinding a10t
Hi, can you provide video? Here you can upload compressed files
Roanne625
Post by Roanne625 »
Z axis grinding with new features are now available online. This factor makes it more convenient for online users. I want to buy HP printer can you please share some info about this. The best thesis writing service helps students while doing article work.
Liana
Post by Liana »
If you are looking for app developers in Dubai To promote your business or to reach your clients easily or for any other purpose then mistersaad is the best approach for you
steve91
Post by steve91 »
Even in the darkest hours of your life, I will stand by your side holding onto the only candle and light up all the non-illuminated areas. May God shower you with all the happiness in the world! Good Bye 2020 Welcome 2021 Quotes!
muttyhere
Post by muttyhere »
After study a few of the blog posts on your website now, and I truly like your way of blogging. I bookmarked it to my bookmark website list and will be checking back soon. Please check out my website as well and let me know what you think. structural engineering assignment help
Damion852
Post by Damion852 »
angelei wrote: Thu Jun 18, 2020 6:54 pm So I just got my a10t geeetech printer in and it worked great but I wanted to add auto level. So I followed the instruction video on the geeetech site and used the smatto firmware updater as it showed. It worked until I pressed the auto home button on the printer as shown in the video and the z axis began making a grinding noise and would barely move. So I figured it might be an issue with the update so I tried flashing it back to the original firmware provided by geeetech for the a10t. It still made the noise but would not move and then the LCD screen started flashing with weird characters and the smatto program crashed. Not sure what to do but I'm afraid to do anything else right now.
One of the motor cables is just barely long enough. Sure enough, the connection was loose. I tightened it and that fixed it immediately. I loosened it just to see, and I got that nosie again. Thank you so much. Sometimes it's the small things that get overlooked.
hipohaha
Post by hipohaha »
The information you shared is quite complete. I will research more on this topic paper minecraft
