I got my A20M about a week ago from amazon, Everything worked great initially.
Suddenly it no longer detects the SD card. Tried 3 or 4 that I have here and nothing.
So I've been using Octoprint with a raspi 3b+. Not as good results a from the sd but ok.
Now the button no longer works at the panel, I hear it click, but nothing. Of course I pwr cycled & press the little reset button.
I was thinking just now maybe it disables this stuff while plugged into usb? I have other printers and they don't do this.
So I would guess my next step is to disassemble it & check connections? This all was pre-assembled, so if they're loose they cam this way.
Or maybe I need another LCD board? They seem cheap enough, but I shouldn't have to be buying replacement parts for a 1 week old printer.
If there any tips for getting octoprint working better in the meantime that would help. Or can I run Eazyprint on a PI?
The other little problem I have is the #2 extruder pumps out alot less than the #1. I took apart the mech and tightened it up some, and cranked up the flow on that side to workaround. 150%. They still don't seem equivalent, but closer.
Otherwise I'm very happy with the quality, much better than my other machines.
Thanks for the help!
new A20M couple of problems??
Re: new A20M couple of problems??
Hi, if the Sd card cannot be read, it may be that the screen line is not in good contact, or the shrapnel on the SD card slot is loose. It is recommended to check.
Life is full of problems. You have to face different types of problems of https://topamericanwriters.com/customwr ... om-review/ on every part of your life. But if you are also facing different types of problems in your life, then you can visit this site to get the solution to your problem.
A particularly magnificent article this is. I truly happy to peruse this enlightening article and it gives us heaps of significant data. Keep it up with this stunning work.
Delhi Escorts
Delhi Escorts Service
Delhi Escorts
Stunning, cool post. I'd like to make like this also – saving time and authentic troublesome work to make a remarkable article… anyway I put things off something over the top and never seem to start. Thankful in any case.
Escorts in Delhi
Delhi Escorts
Escorts in Delhi
Delhi Escorts
This blog is really mind blowing. The information here will obviously be of some help to me. Much appreciated!.
Call Girls in Delhi
Call Girls in Delhi
Call Girls in Delhi
Call Girls in Delhi
