Hi! I have a Geeetech A20 and I am having problems with my last prints.
It starts to print but then stops and beeps and the screen shows: resume print / extrude more
When I print without the filament sensor it doesn't stops, so it seems to be the problem. How could I fix it?
And I have another problem because the nozzle is closer to the bed on the central point than on the square ponts, so I assume the hot bed is combed. How could I fix it?
Print stops every 5 minutes and beeps
Re: Print stops every 5 minutes and beeps
Sounds like a problem with filament? Maybe you can change to a new roll of filament.
Try to level the hot bed again? Or get a new one
