So after finding out how to perform some of my own maintenance after having many issues with my A10T and its firmware, I have found Vert(abreak) online and discovered how to flash over new firmware.
After doing some investigation I am just perfecting the firmware and I need to know if the A10T is a 3 in one virtual stepper or a 3 in 1 physical stepper.
Any assistance would be great.
Mixing/Multi extruder for the A10T.
Gilgawrath
Re: Mixing/Multi extruder for the A10T.
Similar problem.
I'm trying to sort out the "configuration.h" file but sure what to change/ remove to make it correct specifically for the A10T v2.0 and would appreciate any help.
- Przepka1985
- Contact:
On Vert Firmvare you dont need to change anything in mixing areaIamAnubis wrote: Tue Aug 04, 2020 10:11 am Hi,
Anyway you got 3 stepers and one virtual
on Cura I got 8 virtual steppers for mixing, also known as vtool from marlin2
