a10m filament extruder is clicking/slipping mid print
so im new to the a10m and i have gone through the forum looking for the issue im having but haven't found a fix yet. im trying to print the dog that come on the sd card and the filament stops feeding at random causing the print to fail. the extruder motor is spinning like its feeding but the filament wont feed. ends up making a flat spot on the filament and i have to pull it out and re feed the filament. seems like the nozzle is clogging but i clear it out and go again but with the same failure.. any help would be very much appreciated thanks
Re: a10m filament extruder is clicking/slipping mid print
Hello, maybe the printing temperature is too low? Try to increase the temperature of the nozzle. Or you can loosen the screw of the extruder, maybe it is too tight and the filament extrudes slowly.
chris@chrisgrieve.com
I’m having the same issue. Have you managed to resolve your issue? My extruder temperature is 190...
Regards
Chris
Regards
Chris
