I have a problem with my X axe.
when the engine is running, it is as if the belt is blocked by something.
I can run the motor manually.
If I switch the connection to y axe, the problem is the same on this one and the X is working fine.
I have replace the driver but the issue is still there.
The Y and Z axes are ok.
Can you please help me to solve this ?
Thanks.
						X axe not working.
Re: X axe not working.
Hello, there may be a problem with the cable, you can replace the cable.
HEllo thanks for the tip.
I don't have other cable but I will try to test them.
I let feedback.
I let feedback.
This was the issue. I changed it and averything work fine again.William wrote: Wed Sep 02, 2020 1:54 pm Hello, there may be a problem with the cable, you can replace the cable.
