GT2560 A+ Attaching multiple cooling fans
engrost
Post by engrost »
Hi, Have Prusa I3 Pro with GT2560 A+ board.
Want to extend it with Dual extruders, and want to add more cooling fans.
I was thinking of using this design https://www.thingiverse.com/thing:2251319 for attacing fans, but could nowhere find any information where to connect extra fans.
I have only one set of pins for PWM fan on board.
how would I attach more than 1 fan?
are there any other I can use?
MBO
Re: GT2560 A+ Attaching multiple cooling fans
Post by MBO »
Hi Engrost,
I had the same idea, and the solution is: Build yourself a Y-Cable to split the one PWM Signal to both fans.
I have this solution working, Power consumption is ok with two 5015 fans, 0,18A each.
Regards,
Martin
