Looking to gain advice for testing a dead machine with these symotoms:
Switch light works. No motors are on. Screen is blank. Light on mother board is lit.
Can someone with more knowledge than me help? Frank
My A20T is dead!
Re: My A20T is dead!
Hello, can you use USB to connect to a computer for control? There may be a problem with your LCD screen. If your motor does not move, try to swap the drivers on the motherboard to see if it can work normally. If you have any questions, you can go to the place shown in the figure and ask for help from geeetech's technical staff.
- ic.jpg (320.65 KiB) Viewed 10060 times
hi.
i had the same. red light on. display dark.
on gt2560 board there are two 1808 smd fuses. one 10a other 15a.
replaced and all is working again.
