3dtouch sensor a10t
Linmad
3dtouch sensor a10t
Post by Linmad »
Hope someone can help me.
I have made all the intructions to setup the 3dtouch sensor for my a10t and update the firmware to "Firmware For A10T(GT2560 V4.0 Support 3Dtouch-Beta)" and wired everything as explained in the video. I have recheck that all is fine.
When I turn on the printer the 3dtouch sensor goes up and down a few times like checking itself. However when on the screen I tell it to Stow or deploy it doesn't do anything. If I try to print z axis goes down and hits the bed and doesn't stop.
I am very sure everything is correctly pluged. Any idea if I am doing something wrong? Maybe is the sensor dailing? Any way to check it?
Thank you
Linmad
Re: 3dtouch sensor a10t
Post by Linmad »
Forget it, I had plug worng the cables in the pins
Thank you
dazmaltby
Post by dazmaltby »
Can you please post a photo of the connections. I've been searching youtube and the videos are great except that they do not show which pins to attach the BL sensor to on the A10T. I have a three pin block as well as a 5 pin, non-linear, block and I don't know which the wires should go on.
dazmaltby
Post by dazmaltby »
Hi guys - sorry. Just found the info here
http://www.geeetech.com/forum/viewtopic ... 0t#p113207
