There is a small part of about 2x4 cm in the center area of my plate where the filament is not sticking on the plate. See attached picture
Also the plate is not really flat. I level all the corners exactly but in the middle the nose is too far away from the plate surface so my prints won't hold. I could solve this by manually adjusting the levelling screws under the heatbed whith the printhead centered on the plate.
Does the heatbed have to be replaced? The printer is brand new ...
Thanks for support,
Small Part in Plate Center where filament not holding?
EthanElijah
Return to “Geeetech A10 Series”
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
