Hola,
puede haber varios problemas: motores, conexionado, controladores de los motores, cables en mal estado...
Primero revisa todas las conexiones de los motores, que estén en su sitio, como si tienes un motor que funciona, es conectar el motor de ese cable a otro motor y comprobar que funcione el motor. Otra opción que te voy a decir para comprobar si son los controladores, es que cojas el controlador (driver) del eje Y y lo intercambies con el del eje X, por ejemplo, y si funciona en ese momento el X y no el Y sabes que el driver está mal, si sigue funcionando el Y pues el driver está bien, y sería probar motores y cableado.omegle xender
Ayuda con mi nueva impresora?
farnandez
- Location: https://mini-militia.com/mini-militia-apk-tipstricks/
Re: Ayuda con mi nueva impresora?
I don't know Spanish So I don't know what they are discussing in Spanish in this thread (https://www.reddit.com/r/argentina/comm ... impresora/) which I found from reddit and I think it's useful to you to solve your issue..
J.farnandez
gbwhatsapp
J.farnandez
gbwhatsapp
ananyaverma
- Contact:
I used the google translator to translate it from Spanish to English, but its still hard to understand for me.farnandez wrote: Sat Mar 05, 2022 8:13 pm I don't know Spanish So I don't know what they are discussing in Spanish in this thread (https://www.reddit.com/r/argentina/comm ... impresora/)gb whatsapp download which I found from reddit and I think it's useful to you to solve your issue..
J.farnandez
gbwhatsapp
Thethinker
- Contact:
You can use google translator or it's extension to get your text translated from any language.farnandez wrote: Sat Mar 05, 2022 8:13 pm I don't know Spanish So I don't know what they are discussing in Spanish in this thread (https://www.reddit.com/r/argentina/comm ... impresora/) which I found from reddit and I think it's useful to you to solve your issue..
J.farnandez
fmwhatsapp
He is explaining a troubleshoot guide for 3D printersfarnandez wrote: Sat Mar 05, 2022 8:13 pm I don't know Spanish So I don't know what they are discussing in Spanish in this thread which I found from reddit and I think it's useful to you to solve your issue..
J.farnandez
You can use google translator am also using it.farnandez wrote: Sat Mar 05, 2022 8:13 pm I don't know Spanish So I don't know what they are discussing in Spanish in this thread (https://www.reddit.com/r/argentina/comm ... impresora/) which I found from reddit and I think it's useful to you to solve your issue..
J.farnandez
apk
