I have the strangest problem. My A10M won't actually print anything, sort of.
When I start a print, either from an SD card or OctoPi, the printer does an auto home, then a auto bed level (BLTouch), and waits for the bed and nozzle to heat as expected, BUT even after the selected temps are reached, it still says E1 heating.
The control panel shows the correct temps, and OctoPi also shows the correct temps. In order to get it to actually print, I need to go to the cvontrol panel and change the default nozzle temp to something lower, and then it continues. It doesn't make any difference what I lower it to (only 1 degree is enough) nor does it make any difference what the temps are in the GCODE. I re-flashed the same code that I installed originally when I installed the BLTouch (a hex file I got from this forum, Marlin 1.1.9), with no difference. It does the same thing even if the printer isn't connected to OctoPi or not.
I have no idea where to go with this, and Marlin options are too complex to figure out. I only can use the Arduino IDE (no platform.io).
Printer won't print without manual intervention
crusader27529
Return to “Geeetech A10 Series”
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
