Retraction doesn't work on my Geeetech E180
LavenderBirch
Post by LavenderBirch »
I recently received my Geeetech E180 from kickstarter campaign. I'm a linux user so I didn't plan to use their windows only slicer software anyway and people had had good luck using 3rd party slicers anyway.
I installed Slic3r prusa edition and put in these settings
Layer height 0.2
Nozzle diameter 0.4
Speed 40mm/s
travel 80mm/s
Filament 1.75
Temperature 200
retraction 4mm
retraction speed 40mm/s
bed size 130x130x130
And so on, pretty close to what their slicer had as default but no matter what I set to retraction or retraction speed, it simply wouldn't do any retraction. It would always leave the movement lines as if they were print lines.
Another curious thing I noticed is that when I manually extrude or retract filament from the UI on the printer it extrudes in both cases. I thought that was firmware issue so I got my wife's windows laptop, installed their easyprint 3d, updated the firmware and sliced using their slicer, still no retraction.
Any ideas?
igorf7
Re: Retraction doesn't work on my Geeetech E180
Post by igorf7 »
Open the package box Step 2.Take out GIANTARM D200 from the box; put it on the flat surface. Step3. Take out the accessories from the foam box in order.
UPSers website
Baize458
Post by Baize458 »
The Geeetech E180 melts plastic during printing. ... E180 can run stand-alone with a TF card, untethered to your computer. All you need to.
Rapidfs Login
benkayle8
Post by benkayle8 »
