A30T pausing
Grayham62
A30T pausing
Post by Grayham62 »
hello and thanks for admitting me in to your group.
i have a A30T.
latest software version.
using cura 4.1 to slice.
problem.
i have printed a part off that is 200mm tall
after 60mm it starts to pause for a second whilst printing that causes pimples.
as it build higher it get worse, it is pausing every were, inside walls, supports etc..
i have set retraction to 8mm.
and ensured that the other heads are isolated in cura.
the print time is double the estimated slicing time.
Admin
Re: A30T pausing
Post by Admin »
Hello, please try the following configuration file, and then print another model. It may be that your model lacks support, causing the suspended part to not be printed well. You can add support to the suspended part.
Cura4.9_A30T_0.2_PLA.rar
(1.11 KiB) Downloaded 269 times
