Geeetech A10 ignoring temperature settings
JesonMile
Post by JesonMile »
Hi all
I'm new to 3D printing and I recently got a Geeetech A10. It seems to be working very well aside from one thing.
I'm getting a lot of stringing, and the print sticks to the bed a little too well (tricky to remove after printing). I tried to lower the temperature of both the hot end and the bed in Cura, but it seems the printer just ignores it and always prints at 215C on the hot end and 60C on the bed. The weird thing is that it heats to 190C first when you select "Preheat PLA". I'm using Cura if it makes a difference.192.168.0.1 routerlogin 192.168.l.l
Chris97
Re: Geeetech A10 ignoring temperature settings
Post by Chris97 »
In Cura set the "printing temperature" parameter to the value you need. Check the "standby temperature" parameter and set it to the same value as "printing temperature". Set "Initial temperature" and "finishing temperature" to the same value like "printing temperature" too.
