Hey,
i got an A20 from Geeetech and upgraded a BLTouch to it.
I followed the instructions to setting up the right nozzle height.
I adjusted the Z-Offset until a piece of paper (round about 0.1mm thick) is slightly
scratching on the nozzle when Z = 0mm. Therefore my nozzle is 0.1mm away from the
heatbed. Now im slicing a STL with 0.15mm first layer height. Accordingl10.0.0.0.1 192.168.1.254
y my nozzle now
should be 0.25mm away from the heatbed. Am i right?
My problem is, the first layer wont stick well enough on that height and my nozzle seems to just
lay down a line of PLA on my bed and pulling it around the heatbed.
Did i missing something? Do i need to adjust my z-offset, so my nozzle is touching my bed or do i
have to adjust my first layer height in Cura to near zero, so my nozzle is 0.1mm away from the bed
on the start of printing?
Greetings from Germany.
Geeetech A20 + BlTouch = first layer height question
chadcolen83
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
