GeeeTech E180 No Printing - Code: Error Abnormal Temperature
stampa7
Post by stampa7 »
GeeeTech E160 HardwareV.1.6 no longer prints.
Code: Error -0- Abnormal temperature.
The temperature is shown in the display, but the nozzle does not get hot.
Thermistor shows 5.26 kΏ by room temperature.
Nozzle externally heated via bypass from the laboratory power supply, 3 D printing is possible.
What could be the cause.
I have no idea what to do about it.
Morgest
Re: GeeeTech E180 No Printing - Code: Error Abnormal Temperature
Post by Morgest »
If language is the problem where you are making mistake in computer but computer only understand 0 and 1 language to take commands of also you can take things seriously to understand and gain knowledge from https://essayscholar.com/ for your homework that might being done in a wrong way. if you use this website for your further use then you will be surely understood too much things about those behave that supposed not to ignore in writing
