Hello , my printer is ignoring cura temp settings and keeps printing at 215 when cura is set at 195
it also prints a priming line that i do not want , in my cura settings this has been disabled.
i have reset printer a few times but keeps going back to a fixed print temp
Giantarm A20
OrazioGiunta
Re: Giantarm A20
Hi, I've the same problem. About the line printed at the start of each print work it's easy to remove but you should not do this, nevertheless you can accellerate that line by modify this setting in cura slicer:
G1 F300 X200 E40 ; push 40 mm of filament while moving at 300 mm/min to position X=200
I've set F to 500; it's useful to clean the nozzle before start.
Do you have news about temperature setting ?
Re: Giantarm A20
Hello , thanks for your reply ,,,,,,to be honest , i have had nothing but trouble with this printer since i bought it , i have decided to scrap it and stick with my enders , lesson learned
