The Question of Patent Licensing
DerekLewis
Post by DerekLewis »
If I have two products, both of which have active patents. Can I patent the "app" or how I would like to use them together, and if so, what is the name of the process and is there any specific information I need to know in order to proceed with the patent?
DannyG
Re: The Question of Patent Licensing
Post by DannyG »
Theoretically, you might be able to get a patent for a new and non-obvious use of an existing product, but in reality, such patents are almost impossible to get. Ideally, you should have some sort of evidence or logical reason why someone doesn't usually combine the two. On this issue, it would be better for you to contact patent brokerage firms https://patents.kblit.com . I think that they will be able to advise you in more detail.
