Do you have the old version of firmware available or can tell me how to check set this. I have gone over the Arduino thread but guess I am not smart enough.
Firmware for geeetech 3D printers
Re: Firmware for geeetech 3D printers
I have one of the first Acrylic I3 ProB printers and my hotend now heats 35-40 degrees higher that it's set for. I've changed thermistors twice with no joy - so swapped boards thinking it was the firmware. But the the problem with hotend is still there, and the new board must be for the T8 rods (mine has the M10's) - the Z just crawls a couple inches and stops. I don't know how to set it - the LCD 'load' and 'save' features reset after power down.
I use this printer every day and miss it. I hope you can help
is it possible to get Marlin 1.1.9 for the Pro W? Or at least a list of the values that have to be changed in the original firmware?
lauraroz wrote: Thu Jul 04, 2019 5:04 pm A mi me vino genial para impresión 3d para regalos de comunión para niños
Admin wrote: Tue Aug 28, 2018 5:59 pm Hi,guys!
In order to create a more comfortable discussion environment for forum members.
We have to make some rules,
- Mutual respect. Every member should respect each other, which is a prerequisite for mutual discussion. This is like a "mirror". If you don't respect others, we can only tell you with regret: Please leaves this forum!
....- This forum brings together members from all over the world, so be kind and write in English. This will make it much simpler and easier to search the content.
Admin 2018-08-26
Update: 2019-03-02
Hello
Please tell us when a new firmware will be released (Geeetech A30) ?!?
Greets
Greets
Thanks for your feedback.
vincentbcd
I surch a firmware for my I3 all aluminium, with GT2560a+, DRV8825,and LCD upper, bed heater aluminium, please.
Do i install firmware with arduino 1.0.1 or can i install it with better, if yes, wich one?
Thanks a lot for you helping.
Hi, you can refer to this download:http://www.geeetech.com/forum/viewtopic ... 20&t=17046vincentbcd wrote: Wed Jul 31, 2019 10:38 pm Hello,
I hope this can help you.
vincentbcd
Thanks William, i heve ever view that, i would day if i can take Arduino younger than 1.0.1.William wrote: Thu Aug 01, 2019 9:20 amHi, you can refer to this download:http://www.geeetech.com/forum/viewtopic ... 20&t=17046vincentbcd wrote: Wed Jul 31, 2019 10:38 pm Hello,
Re: firmware for geeeteh 3D printers
Hi,you can go through the official website: https://www.geeetech.com/download.html?download_id=34ZIM372019 wrote: Wed Jul 31, 2019 11:09 pmHi, iam very new at 3d printing, do i have to download the Ramps file and the Marlin file? or which one do i need? I have the Prusa I3 pro B, and the board is the GT2560, but iam kind of lost, not sure what to do. thanks for the help!Mark wrote: Tue Apr 12, 2016 5:35 pm Don't use the latest arduino version, usually the latest one will cause this problem, it's not the firmware's problem, try to use arduino1.0.1 or arduino 1.5.2.
download the HEX file,
connect to the printer and update the firmware via
Cura settings -printer-mange printer.
vincentbcd
Hello William,William wrote: Thu Aug 01, 2019 11:57 amHi,you can go through the official website: https://www.geeetech.com/download.html?download_id=34ZIM372019 wrote: Wed Jul 31, 2019 11:09 pmHi, iam very new at 3d printing, do i have to download the Ramps file and the Marlin file? or which one do i need? I have the Prusa I3 pro B, and the board is the GT2560, but iam kind of lost, not sure what to do. thanks for the help!Mark wrote: Tue Apr 12, 2016 5:35 pm Don't use the latest arduino version, usually the latest one will cause this problem, it's not the firmware's problem, try to use arduino1.0.1 or arduino 1.5.2.
Thanks for your helping , it's appreciated.
I have update with new firmware, it s work.... but item was very smaller than real in gcode.
the print area is reduced as well as the object
