A 30 Power supply
rj16066
A 30 Power supply
Post by rj16066 »
Is the GEEETECH A30 a 12vdc or 24vdc power supply?
Re: A 30 Power supply
Hi, You can provide your hardware version number, depending on the version, there are 12V and 24V respectively.
rj16066
Post by rj16066 »
The only number I see is a MPN 800-001-0503
Hi, If you have a multimeter, you can measure the output voltage of the power supply.
Tomyuan
Post by Tomyuan »
Click LCD>Main menu>About
HW is under 2.0 then it is 12V, 2.1 or more is 24V.
cheers
rj16066
Post by rj16066 »
Thank you....
rj16066
Post by rj16066 »
Hardware version. V.3.5 So I assume it is the 24V power supply.
RJ
BobaLives
Post by BobaLives »
If you open the control box and drop out the power supply it will tell you if it is 12V or 24V.
I bought my A30 last year and requested the 24V system, but I received the 12V and after first couple prints the fuse on the back kept popping when the bed would heat up. So I opened it up and was not happy to see I received the 12V (S-500-12) when I requested the 24V. After a back and forth with Geeetech, they sent me everything for the 24V system to upgrade. I made sure to open the control box and check the power supply to see if it said 24V (S-500-24).
This is the 12V power supply. I am printing with the 24V now, so I cannot open and take picture.
12V power supply
12V power supply
