Driver Settings for A10M with easyprint3d
go2xt@me.com
Post by go2xt@me.com »
hey ,
sorry for my english it is verry bad sorry for this.
, i need the Printer File oder settings for the a10m. i use the geetech easyprint3d there is only the a10 in the pre settings
thx for the help
I buy my fist 3D printer in june /2019 a Geeetech A10M
i think i must learn about 3d-printig a lot the next time
Re: Driver Settings for A10M with easyprint3d
Hi, I will send you the A10M configuration file for you.
Chub
Post by Chub »
Is Easy print 3D a decent slicer? I also have an A10M. I am currently using Cura 4.0.
:D Easy print also a slicer software, and you also can use Repetier-Host.
Chub
Post by Chub »
Can you send me the config file for the A10M for Easy print
Hi, Repetier Host is recommended, you can go to the official website to download.
go2xt@me.com
Hi, wre you sende the File?
I donload the Repetier Host file vom GT but i can`t import it in easyprint3d, the import files are only .ini
what is my mistake
:D Hi, If you downloaded the Repetier Host configuration file via the following URL, https://www.geeetech.com/download.html?download_id=31
You need the following:
First set the parameters of the printer,
Secondly, connect the printer;
Then disconnect and select the configuration on the right side of the slicing software;
Select Print-import-select A10M PLA high .rcp to import and save;
In the material -import-select A10M PLA high fi.rcp to import and save, complete the configuration.
xBiker
Post by xBiker »
Hello, could You please also send me the config file for the A10m for Easyprint3D?
Nicolas M.
Post by Nicolas M. »
I also need the configuration file. Could you send it please?
