A30 Bed leveling
rj16066
A30 Bed leveling
Post by rj16066 »
I have spent more than 10 hrs on two different days trying to manual level this bed. I have no issues with the CR 3 pro, but this thing will not level.
If I get all four corners correct, the middle will not touch the A4 paper, but if I get it to touch then the 4 corners are out of wack; then the first layer in the middle is so messed up and it depends on what portion of the bed it is on then it will get too close clog the nozzle and I have to stop the print.
I have watched every video made by Geeetech on this as well as others but it is not working. Really regretting this purchase.
Re: A30 Bed leveling
Hi, You can try to remove the hot bed to see if the hot bed is level, if it is not flat, you can replace it;
Or use the screen to move the nozzles at various points on the hot bed to see the situation.
rj16066
Post by rj16066 »
With help from the community, I was able to dial in the A30 heat bed. BUT... This is what happens during the print. Any suggestions?
Printer issue on the A30
Hi, You may need to do the following
1. Leveling the hot bed;
2. Check the tightness of the belt;
3. Appropriately reduce the printing speed, the recommended range is 30-60mm / s.\
I hope this can help you.
rj16066
Post by rj16066 »
Thank you for the suggestions.. I will give it a try.
Cheers
RJ
:D
CallXYZ
Post by CallXYZ »
Are you trying to print the A30 example file?
Is the print loosening from the plate and / or sticks to the nozzle?
rj16066
Post by rj16066 »
Yes, I was trying to print the Monk that came on the micro SD card. It printed fine on my CR-3 Pro, but not on the A30.
I finally got time to work on the A30, I have created a g-code for a hand and it seems to be printing fine at the MOMENT.. But we will see if it completes
well.
Cheers
RJ
